Sounds like I need to swap my tires 🙁Guessing snow/slop? Didn't they get a like 30" of snow 2 weeks ago?
😡😡🙁Does it matter, you ain't gonna sleep for shit the night before.
U will continue to have a blast.What should I expect I'm new to it I'm having a blast already
26x5 with all thst snowI know that it's going to be a tough course I'm racing to have fun and meet people and learn I'm running 29x2.3 is that going to be fine?
What tire are u running?I know that it's going to be a tough course I'm racing to have fun and meet people and learn I'm running 29x2.3 is that going to be fine?
Should read him a bedtime story.Does it matter, you ain't gonna sleep for shit the night before.
You should be fine, they will hold up to rocks.Specialized ground control in the rear and the purgatory in the fron
Everything tire is different, so tires will react differently with the same psi. If running tubeless, which I hope you are, you want to run low enough pressure to flow over rocks without bottoming out and putting too much stress on your sidewalls. Also the weight of a rider will determine your psi. Ballpark would be 17-21 psi...but you'll want to experiment to see what works for you.Don't mean to steal any secrets but what would be a good ideal tire pressure for the course?
