29er wheel question
ADZ
So I have a 29er with Bontrager rhythm comp rims and I am going to be doing a 200 mile charity road ride next month. I would like to put some urban tires on the bike for this ride, I have been looking at a set that are 700c X 34, also 700c X 36.
So here are my questions.
1. Can I put 700c tires on a 29er rim?
2. will 700c tires that need tubes fit on a tubeless rim?
3. whats the thinnest road tire anybody would recommend on a mountain rim?
Hope someone can answer this for me.
cheers
A
bonefishjake
since i only know the answer to #1, and that's "yes", i'm going to punch out and let someone who is actually edjumacated about bikes answer this.
P
pdm362
Guest
I am not sure about the other two questions but I am not sure about doing 200 miles on a mountain bike. you have the right idea about putting skinny tires but it will definitely be quite a punishing ride. See if you can get a cheap rigid fork in ebay or craigslist. If you are riding a FS it would be a little tougher.
If you can't get a road bike try to demo one from competitivecyclist.com and do your chairty ride on an awesome full carbon sucker. This way you save some money and enjoy 200 miles on a 14 lb bike. Just my 2 cents.
Paul
Steve Vai
-Yes, albeit a hybrid tire, on a Rhythm rim you most likely won't get anything narrower than a 38c.
-You're wheels are not tubeless, they are "tubeless ready", that means it needs a different rim strip, tire, and tire sealant too make it tubeless. If you have all that stuff, just remove the valve core and insert a normal tube, it will work fine.
-See answer #1...
-Jim.
ADZ
-See answer #1...
-Jim.
Thanks for the info, that's the answer i was looking for. I have been putting slicks with tubes on my 26er mountain bike tubeless rims for the past three years, can't justify buying a road bike for one 200 mile ride. I can't find a slick 29er tire, so i am going to chuck on a hybrid.
I have the paragon 08 29er, it has the tubeless ready rims and tires. I think i understand now. just because it has tubeless rims and tires, you need the sealant and rim strip to make it tubeless? So if it has a tube in the tires now, can't i just put on a regular tire?
cheers
A
anrothar
entirely thrilled
ah, you will need a narrower tube for a tire that much narrower. you could squeeze your 29er tube into a 38mm tire, but it'll be difficult. and you can run a much narrower tire than 38mm. i've been running 32mm tires on 28mm wtb dual duty freeride rims for over a year with no problems.
