ChrisRU
Ideally, you want all of your audio and video sources routed directly to your A/V reciever. You would then use the HDMI out on the reciever to send video to your TV.What is the preferred routing of audio/video assuming enough HDMI ports on both the receiver and TV?
Most recievers have no issues doing this, but there are some with reported problems. Make sure there are no filters or signal processing being applied to the video signal. Some recievers have processing features but you really want to pass native signal and adjust picture using your TV. You also want to make sure you have your TV configured correctly, what your seeing could be the result of your TV processing a recieved signal differently (e.g a 24p blu-ray signal vs a broadcast signal).
