xc62701
I'd gladly lead a hill road epic some weekend in the near future in the Sussex Warren co. locale
I'd be down for that...
Skyline Drive from either side is quite a pedal
Schooleys Mountain Road from Long Valley is pretty rugged
Brookvalley Road from Lincoln Park over 287 into Butler
I was gonna mention Zellers; if I remember correctly, it has a great switchback which will just about induce a wheelie.:getsome:
peachcroft in peapack/bernardsville and claremont rd (starting from the b'ville train station all the way up to mountain) come to mind...
That brings up the question, where does a climb end? I did 4 of the hills listed in that page linked earlier, and it's easy enough where to start the lap. But take Schooley's Mountain, which I did today. When you're done with the bulk of the climb, it turns almost a false flat. I took it all the way up to the traffic light, probably doing 15+ by the time I hit it. That sort of invalidates the whole "hillclimb" concept.
good stuff norm, I am pretty exicted to do this on some of the hills in my area to see how they rate.
Norm, where do you get grade %?
If you want real precision you should graph out each hill profile 😀 I started looking into it at lunch, I think I can get the data to actually do it. There is fairly accurate elevation data available for free (coverage includes much of northern NJ) which will be more reliable than GPS elevations.
Where is Fiddlers Elbow?
There was a downhill before I started climbing Fiddlers that just went on forever. It was pretty darn steep. I do remember from the map I was going through the town of the same name.
Then after I climbed it, I went down a very, very long time, but not as steeply IIRC. Much wider road and better pavement.
There is also a road called Breakneck in Vernon that I've read about. The guy classifies it as the same as Fiddlers, ranking them both at #1 in the state.
