syadasti
Wet Rag
I have a MTB frame I built up and its only reamed about 220-250mm deep - there is a small bit of weld (1/16-1/20 thick") that is blocking the seat going any lower and the manufacturer's ream was too short to get it (all frames have the issue). I'd like the ability to lower my seatpost more without cutting it.
Anyone have a 30.9mm ream that can go at least 10" deep? The last time I needed a seat tube reamed years ago none of the shops around had a ream. It was not a huge issue as it was just for burrs that were scratching a seatpost, not a weld which probably needs something more than sanding attachment on a drill cable attachment (the fix for the burrs).
