carbon handlebars ?
olegbabich
I see that there are two diameter sizes, 24.5 and 31.8. Which one should I get for my new XC that I'm building and why? It will be a Full Suspension SS - 26.
Unless you already have a smaller clamp diameter stem you should buy the larger one. The larger dia. will have greater strength at the same or even less weight.
This is the same reason you see larger diameter tubing used for frames, steerer tubes, seat posts, etc.
