Face Book Question
Is there a way to log in so others can not see you, like an invisible mode?
Go to the Chat popup in the lower right, then select Settings. You can select Go Offline.
I believe this will keep people from trying to Chat with you. Not sure though. I haven't used it.
Yes, it renders you invisible. I use it all the time. Once you turn it on it stays that way until you set yourself back to online. So you don't need to do it each time.
