How do i replace the brake pads for the julie brake?
jdog Shop: Halter's Cycles Shop Keep Feb 2, 2009 #2 TWITCH1 said: How do i replace the brake pads for the julie brake? Click to expand... Pull out the locking pin. You may need to bend it back to straight. Take out the wheel. Pull the pads down and out. Push the pistons back in so that there is room for the rotor and the new pads. Go ride.
T TWITCH1 Guest Feb 3, 2009 #3 sounds easy enough... What brake pads should i get? I found a set by koolstop that claim to fit the julie. Does anyone know of any others that have a long life? I'm not to hard on brakes usually.:hmmm:
jdog Shop: Halter's Cycles Shop Keep Feb 3, 2009 #4 The issue with Non Magura pads is that the metal backing plate can be too thin. As they wear they can heat up too much and damage the pistons.
T TWITCH1 Guest Feb 3, 2009 #5 WHERE can i find magura disc brake pads? Never had to look b4 and i dont recall the web site for magura selling them.
jdog Shop: Halter's Cycles Shop Keep Feb 4, 2009 #6 Since you are in cape may I doubt you would drive to me. http://www.webcyclery.com/home.php?cat=289&page=1
