Early Spring Cleaning...
Purple Liquid
Shop: Efinger
Cleaning out my basement: :)
Shimano LX Dual Control Levers w/ Hydro Brakes and 160 rotors
-0 miles on the system.
-If you are not a fan of Dual Control, LX Hydro Brake levers do not cost much.
-These are amazing brakes.
-6-bolt rotors with hardware.
-This is for front and rear brakes/shifters.
Sold!!
Shimano FC-M542 Crankset 175mm w/ BB
-Less than 100 miles.
-44/32/22 rings
-Solid, sturdy cranks in a nice grey color.
-You never go wrong with Shimano cranks.
$65
Sram X7 Trigger Shifters
-Cables included.
$35
Van Dessel Carbon Cross Fork
-New, never installed.
-Uncut aluminum steer.
-50mm offset
$75
Specialized Post w/ Seat
-2014 butted alloy, single bolt setback, 30.9 x 350
-Specialized XC MTB, hollow Cr-Mo rails, SL foam
$40
Ergon R2 Magnesium
-Meant to be used with GRIP SHIFT.
- Very, very comfy. I don't run Grip-Shift anymore, so these can't help me.
-Large pad.
$25
XO Grip Shift 9spd
-Stupid light.
-Left shifter has a cracked gear display. Shifters still work flawlessly, just a cosmetic thing.
$30
Shimano 44 tooth 9spd Chainring
-Came off an LX crank.
-Never used
$20
I will be adding more as I find more. I live at Chimney Rock, so local pick-up is preferred.
Pictures will be added, and any questions are welcome!
Here you go!!
(it was taken on my phone camera, so sorry for the poor quality :rolleyes:)
I love it! Quick release for the TP.
you guys are redunculous :rofl:
BUT why you don't use gripshift anymore? I'm considering trying. How much use those shifters see? Those were the ones from your Scott?
I don't use grip shift because I wanted to try triggers. Just a change of pace, that's all. Sometimes I do miss dumping all the gears in one twist though.
They have a fair amount of use on them. The way I cracked the left one was falling backwards when doing a wheelie :rolleyes:. However, they still work great.
I'll take pictures when I get home from school today.
-44/32/22 rings
$65
I may take this, can these rings all be removed individually? I can probably use this for a single speed build I am doing.Pic for condition please. Thanks
Google man, Google. That crank has a four-arm spider. Rings can be removed individually. Just be careful. Availablility of other ring sizes may be limited.
Good point. Still interested.
Yes the rings can be removed individually (Thanks Ben!!)
Here are the pictures. There is not a scratch anywhere.
These pictures where taken in my basement - anyone care to help with painting? :rolleyes:
More pictures!
First one is the Grip Shirt. Yes it's cracked, but it always works flawlessly.
Second is the set of Ergons.
Good stuff :)
I'll take the brake shifter combo = PM me your adress and I'll send a check or something like that.
Last chance guys... I'll give these sales till the end of the week, then eBay.
C'mon, help a college bound boy support his laptop fund ;)
