JDurk
Fluid looks much clearer than what just came out of mine.Great day for a rear brake gravity-bleed on the Ripmo!View attachment 209345View attachment 209346
In the future, I think I'll do it on an every six months schedule but maybe not replace the seals every time, depending on riding conditions.
Fox recommends sending them in for the full service rebuild every 125 hours or once a year!! I'm not sure if people follow this schedule but it seams excessive, especially considering the cost and downtime. For what it costs, you could buy a brand new fork after about five years, and half that time if you ride a lot and follow the 125 hour recommendation. I'm thinking I'll wait until the suspension feels like it needs it. Or, will I regret this?
I just bought a seal kit for my boxxer 05 it came with wipers oil seals and foam rings. Do the foam rings replace the oil seals?
Yeah, I heard about the slow degrading thing making it difficult to know when it's gone really bad. I think sending out every other year is reasonable. Maybe I'll find a trail section to run to better assess the slow degradation and feel of the suspension over time.Seals every other service is pretty normal. Foam rings every time.
I think the issue is your fork doesn't go from "hey this is great" to "oh this is terrible" overnight. More of a slow degrading thing. That said, I don't think most people send their fork out annually...If I kept my bikes for longer than a year I'd probably send out both shock and fork every other year. Which would be a nice thought if I didn't have a smattering of Rock Shox, Fox and DVO between my bikes.
Good to know propain warranty process is quick and easy. Didn't like how wide the rear end was at hub interface , made starting thru axle somewhat difficult. It was close to 8 mm to wide . Once axle was tight everything lined up properly. An email , some pictures and a week later got my new swingarm.
My alignment was fine . The spacing was pretty wide like it was super boost instead of reg boost . I just emailed with my problem sent some pics and measurements.I think I have the same issue. The rotor is rubbing on the chain stay. What did you send them?
Also any 2 piece rotors and or hope rotors are just to finicky to get right . My evils didn't play well with trp 2.3 2 piece rotors it was just to bulky . The reg trp steel rotors fit fine albeit tight but most frames are now .I think I have the same issue. The rotor is rubbing on the chain stay. What did you send them?
Looks dialed...like all your bikes. When High Bridge opens back up, let's plan a jump sesh (unless you know other spots?) Thing looks like it would rip on the Vernon paved pump track.Finished swapping parts over to new dj frame , she's smooth . Can't wait to actually hit some dirt jumps this year .
Yes lol , highbridge would be pretty low on that list . Unless you ment the NYC version that and Cunningham are pretty legit .unless you know other spots?
I try to avoid NYC like the plague. Been to Cunningham once though and agree the jump spot is legit.Yes lol , highbridge would be pretty low on that list . Unless you ment the NYC version that and Cunningham are pretty legit .
It's off, way off.Also any 2 piece rotors and or hope rotors are just to finicky to get right . My evils didn't play well with trp 2.3 2 piece rotors it was just to bulky . The reg trp steel rotors fit fine albeit tight but most frames are now .
Boost<151.1<Super Boost
Imho nothing wrong with that . That's about what my replacement swing arm was . My original swing arm was like 12mm to wide .
