one piece crank
Which bike that? Oozing with class
Thanks. It’s a labor of love - a 2021 Haro F&F built to look like an ‘82 Torker. I rode a Torker in 1982, and Torker built the first Haro Freestylers in 1982-83.
Dean S
Got pics? Trying to rectify a floppy bag as well
Yep, on my Ruthworks I've got the Berthoud decaleur bolted to strip of aluminum, something from the floor trim aisle. I like a full loop. Ends are aluminum-taped shut, works well along with side coroplast stiffeners. I'm not using a bottom stiffener, the bag flops over my M-12 a little and stays pretty steady.
Kaleidopete
Changed the tire, damn, these Maxxis are hard to break the bead on.
I don't know if it's the tires or the rims that make it tough, most likely the rims.
I used my bead breaker, that's the only way I'm getting it done! Just barely.
I made a larger better one for next time. No way I could ever do this on the trail.
Juggernaut
Master of the Metaphor
Lay the wheel on the ground and step on the tire near the bead…. Bam! Bob’s your Uncle, it’s off. 😉
