Wow, 1st time tubeless? 2-4oz works perfect. It will need to be refreshed after some time. Check it by shaking the tire in 30-60 days.R&R my 1st tubeless. New 29 x 2.4 Rekon. Mounted up smoothly. Holding air with no sealant.
I’ve heard to use some where’s from 2-4 oz of sealant to setup this tyre new. I’m leaning to 3 because Idontknow. What say youz? Will it work?
Splitting btw 2 wheel sets, tires last awhile. Got over 2000 miles on the first Rekon, no issues.Wow, 1st time tubeless? 2-4oz works perfect. It will need to be refreshed after some time. Check it by shaking the tire in 30-60 days.
My evolution as a home mechanic has been to watch the videos/RTFMs, buy the tool(s), and then try. That said, I'd be lying if I didn't admit that doing the MTB suspension stuff has been a huge learning curve. I bought this thing on Amazon, supposed to be decent. Yay or nay?Unless you have the specific tool (or worked out something similar, i.e use a very sharp wheel bearing separator) and/or don't care about markings on the fork CSU I would just have the LBS remove it for you. They will probably do it for free or very cheap and in about 30 secs.
That’s what I had in mind but I already had the tool from my automotive home mechanic previous life. The only used forks that I had coming with a crown race were my Salsa Firestarters so when I had to replace the crown race I decided to go the safe route and to be honest it was worth the price ($0) and I had 0 nicks on the pretty carbon. But yeah, if you don’t want to spend the $$$ for the proper tool that should work as long as it can grab the edge of the crown race solidly.My evolution as a home mechanic has been to watch the videos/RTFMs, buy the tool(s), and then try. That said, I'd be lying if I didn't admit that doing the MTB suspension stuff has been a huge learning curve. I bought this thing on Amazon, supposed to be decent. Yay or nay?
Amazon product ASIN B072P6J4T9
Wow, hope the bike is ok!!! It's so bizarre how that can happen.On trail...fixed the noise in my rear wheel.
Yeah, riding trail I went down a drop and the stick jumped up and around the wheel like that.Wow, hope the bike is ok!!! It's so bizarre how that can happen.
If those are the type the screw in from the bottom and are captured by a small nut.Shaved down some pins…
So we could avoid another trip to the ER…
We did that too.If those are the type the screw in from the bottom and are captured by a small nut.
Just unscrew them like halfway next time. No need to grind them down.
You can also get formed pins in different heights. I always remove "threaded" pins.We did that too.
I hadn’t thought of that. Thanks for the tip!You can also get formed pins in different heights. I always remove "threaded" pins.
