New Bike, Looking for Protection
so i just got notification from invisa frame with my DHL tracking number it is showing scheduled delivery tomorrow 10/12. Mind you i ordered this 11pm on 10/10 AND IT COMES FROM THE UK!! Why do I pay for UPS to ship stuff cross country in a week when i can order from the UK and get it in 2 days anyways????
oh and sidebar this bike rips
another update: installed the invisa frame, it came out alright, not perfect but i suck at vinyl and really dont have alot of patience. if it holds up great, if not screw it
Not to necro post, but this thread seemed relevant enough. Almost 3 years later, what's everyone's best suggestions for carbon frame protection? Invisaframe? AMS? 3M?
I'm still using the same roll of helicopter tape from when this thread started. Used it on 5 bikes so far and the tape still looks new.
still using invisframe, i actually just sold the bike i had it on when i made this threa, it looked fine. showed some wear but thats what youd expect after 2500 miles. i put it on 2 of my own bikes since and 2 of my friends bikes no complaints from them. imo they are the only way to go for a custom cut frame wrap. if you only want to do a few sections helicopter tape is cheap and works the same.
Thanks for the recommendations. Prolly gonna go invisiframe. I estimate a 6 hour install for my dumb ass.
Good choice. I've had Iniviframe on my Mach 6 since new and so far so good with tons of runs and crashes at Mountain Creek.
Did you ever do this?
because this:
I did RideWrap on our new YTs. Basically the same stuff. Use copious water. Get an Exacto knife set if you don't have one; there's always that spot that just won't sit down. I just split it for more flexibility. Also, trouble bubbles can get popped and smoothed out. The last one we did took less than 2 hrs (frame and fork).
I found with the smaller pieces, chain and seat stays, etc, use less water then you think, just enough to be able to slide it around. It takes forever to squeegee a lot of water out of those little pieces. A trick I picked up, when squeegeeing the water out, use the micro fiber cloth to soak up the excess water as you press it out. Towards the end I felt like a pro but those first few pieces had me questioning why I even bothered.
because this:
I put this on my new frame last year and it was relatively easy. It does take time and patience but it's not difficult. There are videos out there that give some good tips and tricks. My suggestion is to do it where you have good lighting. Have a headlamp handy as well if needed. I found that I can use less water/soap mixture as I got more comfortable putting the pieces on speeding up the process. Too much water and the pieces slides around too much and your spending time squeegee-ing the water out so the piece can get tacky and stay in place. You can always re-wet the piece and move it early on. Keep an eye on aligning and centering the pieces so they fit together properly. I think some of the larger pieces have centering notches.
Edit: @Big Dumb Animal beat me on the less water tip.
Glad this thread came to the top since I was thinking about doing this to my new to me TJ. I don’t plan to really ride the rough stuff but just thinking even at places like Nassau and 6 mile or SSP it can help me avoid any extra scratches and dings.
Do they sell frame kits for specific bikes or do you have to cut to fit yourself?
If it’s cut to fit I can already see it will be a disaster if I try to do it.
All Mountain style on all my carbon mtbs. Very easy to diy
https://www.jensonusa.com/All-Mountain-Style-Frame-Protection-XL-1
Invisaframe is cut to exact measurements. I did it on the fugitive and it took more patience than I can actually spare for a month. It's been holding fast for two years. The good thing is that while the adhesive is still activated by the water you can actually peel it off and reinstall if you're not happy with the result (bubbles, folds etc.). In my case I did a raw aluminum frame with decals, so I had a tiny spec of decal detaching once I removed one section of the film after a less than optimal installation. Made for good motivation to do it right the first time. It works best on continuous, smooth lines while it tends to lift at the edges in small, angular parts of the frame.
TBH, on the Timberjack I wouldn't use invisaframe, I would go with 3M Heli tape because it's mostly regular tubing relatively easy for the tape to conform to. I have used 3M 18mil on all my Salsa frames so far, the El Mariachis turned out much better than the Mukluk because of the more classic, round shape of the tubing.
I'm also looking into Gorilla Tape Crystal Clear tape, it's a little thinner but looks like it would do the job.
As stated, InvisiFrame is frame/size specific, cut to exact measurements. For your TJ, I'd just go with @rick81721 's suggestion. Protect the downtube, and anywhere that cables may rub.
