IP adress banned
FFT
Gay & Stuffy
Is there anyway to renew an IP adress to get beyond an administators ban in a vbullit forum?
what did you do ray?!?
you didn't talk about ibex bikes did you? musta been a good one...
They have blocked the network I am on, is it possible to change the adress of my router?
If they've blocked an entire sub-domain then you really have no chance. The IP address of your router is going to be internal to you - at least the IP address that you can change. So you can make it 1.2.3.4 but it only matters to you and your local area network. The outward facing IP that MTBR blocks is going to be provided by your company's ISP.
You could get a new job.
Did you try logging in at another workstation? If that works, and you have a static IP address you are toast. If you have a dynamic address you can try to release and renew the address from the command line.
It's been a while but I *think* it is:
/ipconfig release
/ipconfig renew
USAGE:
ipconfig [/? | /all | /release [adapter] | /renew [adapter]
| /flushdns | /registerdns
| /showclassid adapter
| /setclassid adapter [classidtoset] ]
adapter Full name or pattern with '*' and '?' to 'match',
* matches any character, ? matches one character.
Options
/? Display this help message.
/all Display full configuration information.
/release Release the IP address for the specified adapter.
/renew Renew the IP address for the specified adapter.
/flushdns Purges the DNS Resolver cache.
/registerdns Refreshes all DHCP leases and re-registers DNS names
/displaydns Display the contents of the DNS Resolver Cache.
/showclassid Displays all the dhcp class IDs allowed for adapter.
/setclassid Modifies the dhcp class id.
USAGE:
Options
If its the entire network, its probably the gateway router IP that has been blocked. Your pretty much SOL...
you could do a little research on how to mask your IP.. I mean kids in China do it all the time when they want to look at youtube... it is possible
