No, that's not what they are.And or cable hold downs? They should come with a screw to attach to fork...if they are cable hold downs.
This is actually the correct answer. There should be 4.They go on the bolt heads and supposed to stop it from unscrewing
I only need 2. I used to pitch and played 3rd base. Got mad throwing skillz.This is actually the correct answer. There should be 4.
If I remember correctly, 4 were supplied. Two for the caliper mounting bolts and two if a disc brake adapter is used. If post mount, then you only need two. Not sure how you ended up with three. Now you have a spare.I only need 2. I used to pitch and played 3rd base. Got mad throwing skillz.
Prolly already threw 1 at a carNot sure how you ended up with three.
Actually there was probably another in the bag along with some other hardware. I just grabbed three to position them in 3 different angles for the picture to show a full depiction of what it looks like.If I remember correctly, 4 were supplied. Two for the caliper mounting bolts and two if a disc brake adapter is used. If post mount, then you only need two. Not sure how you ended up with three. Now you have a spare.
