Pearl
THIS CHANGES EVERYTHING
So the new rig has these TRP Sprye SLC brakes, the ones with the two pistons I can adjust. It seemed simple enough to dial in, but I can't get this thing to stop the way they should. It almost feels like the lever is not being pulled hard enough.
These are Sram levers. I've tried to pre-load the lever, double check how tight the cable is, sand the pads/rotors, center the brake/pistons closer... I can't even get these things to lock up on me.
I did notice it has CGX-SL Jagwire cable housing. A lot of research says that I should be using compressionless housing. This is "low compression". Is this my problem?
Am I expecting too much from that disc life, or am I missing something?
Everything I've read said that these are super powerful, blah blah blah. HALP
