Totally random refrigerator question
wonderturtle
I just got a mini fridge and there are two Cooper tubes in the back that have foam on them.
I can’t find any indication whether i am supposed to take them off (ie, they are there just for protection when in the box) or if I am supposed to keep (maybe provides insulation to the tubes?)
Thoughts?
if its a fridge those are either high or low pressure lines, the high pressure lines will be warm and the low pressure cold(er) you decide which one you think you would want insulated or not. . . you should be able to run it and feel the tubes gently, (if it were me i would remove it from any warm/hot lines and leave it on any colder lines)
These days it seems that anything to be removed will have 37 stickers on it to remind you.
That was my overriding thought ... if these were meant to come off there would be big stickers but the foam was the same as the packaging so....
