The maximum is 18T. I found that out the hard way when the chain started slipping under power. It does state this on the Problem Solvers site. You can use mine if you want, since SSaP is dead.
WTF.
https://www.bikereg.com/singlespeed-usa
The Chameleon has a swing dropout so I would probably use that if I do this. I got the Problem Solvers for the full suspension SS.
Shit, you’re right. I didn’t think about xd on that bike.You sound like you haven't registered yet. Have I ever steered you wrong? Go register. An extra quick link and 10 minutes time and you can have a singlespeed bike. Order the Problems Solvers singlespeed cog adapter for an XD driver now.
Stan's wheels? Easy, get a Shimano Hub, regular singlespeed conversion kit and cog. Now you're down to a 5 minute switch.Shit, you’re right. I didn’t think about xd on that bike.
The Chameleon has the factory RaceFace wheels with whatever hubs. I have everything to make any Shimano hub SS, I just completely forgot this one is XD. I'll have to grab this adapter of which you speak as I don't have any other Boost wheels I could use.Stan's wheels? Easy, get a Shimano Hub, regular singlespeed conversion kit and cog. Now you're down to a 5 minute switch.
-Steve
@gtluke the White Industries freewheel remover fits better. I find the Park one only kind of fits.
That said, WI freewheels are stupid tight fits. I once struggled to remove one using a BFV/the wheel as a steering wheel after spinning it down finger tight. Yes greased, etc...
Lucky for you, you can buy the sprocket portion separately from the core if you call WI.
eh, that would make it unthread while pedaling.
I ran 32/16-21 on my FS topfuel ss with YESS etr-d no problems once I stopped ising mixmatched parts.The maximum is 18T. I found that out the hard way when the chain started slipping under power. It does state this on the Problem Solvers site. You can use mine if you want, since SSaP is dead.
no, my rear setup is weird. It took me a long while to figure out they even made a hub like this.Wait a second, are you running a front freewheel AND normal rear hub? The rear wheel is suppossed to be fixed. Has nothing to do with your skipping issue but is straight up suicidal for a trials application.
It's fixed, but shimano splined for a 6 speed cassette.
yeah, super annoying for doing what I'm trying to do. I just want to dork around at a bike park but keep the bike able to do trials stuff.Woah. Never knew they even made that. Must've been made just before they changed 26" rules to allow Single-Speeds.
Why?Wait a second, are you running a front freewheel AND normal rear hub? The rear wheel is suppossed to be fixed. Has nothing to do with your skipping issue but is straight up suicidal for a trials application.
