gtluke
The Moped
Going out of my mind. I can't get my street bike to work properly.
18t on the front, 12t in the rear. If the bike is in motion and a decent amount of torque is applied the chain skips.
I put a new 1/8" chain on and it got WAY worse. Like you can watch the chain ride up on the rear cog just in the stand. With the 9 speed chain on it'll only happen while riding it. I can't take any more links out of the chain.
The front freewheel has a little bit of play in it, but not bad. I tried to swap it out but I think it's a permanent part of the bike now. Maybe heat will work, but if it doesn't I probably would cook the grease or the bearings so I don't want to try.
Chainline is dead nuts on.
I THINK the problem is using the chain tensioner which keeps the chain too far off the back. It won't work putting pressure upwards, not enough room.
Halp, it works with the old 18t cog in the rear but I wanted to try some higher speed fun times.
switching to regular MTB parts would require a new hub and new cranks. I have cranks, but I would rather not have to buy a hub and lace it up. A MTB rear wheel won't work because of the magura brakes needing a rim that's so wide.
Maybe I need a 3/32 chain with a half link and get push up mode to work? or maybe 12 teeth just isn't enough?
Chainline
Tensioner
I gave up, even the impact gun didn't move it.
Chainline
Tensioner
