Shogun 400 56cm Fixed Gear plus Original Parts - $350
The time has come to part with this beauty. Shogun 400 frame in good condition. Measures approximately a 56 cm, this bike fits me and I ride a 54/56. Paint job is in decent condition, many small nics and scratches but overall looks good for an 80's frame. I used por-15 on the bottom of the driveside chainstays and both drop outs. You can see where the wheels mounts where some of it started to come off. No other rust spots that I noticed. This frame can do it all, has ample room for cross tires, has fender mounts, can be/is set up fixed… I want to just recoup some of money I put into this. I pretty much replaced every part on this bike so here are the specs:
Formula hubs with CXP22 rims, need a slight true
Panaracer Messenger Tires, 25mm front, 28 rear, both in good condition.
Uno seatpost
Does include a seat, whatever the original was, nothing special
Vintage codo ste, also includes a brand new nitto stem, 70mm
Nitto handlebars
Paul components shorty lever
Fizik bar tape
Original brake with newer blue pads
Sugino cranks, 170mm
Sugino bottom bracket
Surly cog 16t (has some corrosion)
Shimano 520 clipless pedals
So the only thing that is original are the brake(s).
As a bonus to someone that may want to have gears I will also include..
Original rear wheel with freewheel cassette
Original cranks with double chainrings
Original brake levers
Shimano 105 downtube shifters
Original brakes (the front was noted above)
Shimano derailleurs
The pictures in the closet are from today
The other pictures are to show with the original parts.
Uno seatpost
Nitto handlebars
Fizik bar tape
Shimano derailleurs
