So I'm getting my ass kicked setting up this stoopid old skool axle. What seems to keep happening is the drive side end cap gets loose, then the whole deal rotates some and over tightens the cone side adjustment. So I've got a wobbly axle on one side and jammed up bearings on the other. Hope my explanation makes sense here...
One method I saw was to tighten the drive side completely (I guess I'll have to hold the axle with pliers in the middle) then do all the adjustments from the non drive side. Which is how you're supposed to do it, but it's easy for the whole assembly to spin if you can't hold the drive side end cap. Thanks.
Various pics/links of the design.
http://cycle.shimano-eu.com/media/t...003/SI_4DA0B_001_En_v1_m56577569830646896.pdf
