Fire Lord Jim
Champion Tire in Ringoes!Not on the road but major tubeless fail. By the time I realized, the bead got all screwed up. Wonder if HF has tires
Those tires are a royal pain to reseat usually. I use a ratchet strap on the center of the tire to try and bow it out so the tire touches the bead while inflating.Not on the road but major tubeless fail. By the time I realized, the bead got all screwed up. Wonder if HF has tires
I do the same, but with the broken bead, need to replaceThose tires are a royal pain to reseat usually. I use a ratchet strap on the center of the tire to try and bow it out so the tire touches the bead while inflating.
The Pro1s I had - first set worked great, second set not so much. 28c's barely fit and were plush.
You should be able to patch the hole from the inside with a tubeless patch kit. Although I have no experience patching road tires and their higher pressures.I've had my road bike about 2 months now and today I had my first puncture. I plugged the tire as the sealant wasn't able to fully seal the hole. I topped it off with CO2 and went on my way. Can I continue to ride this tire? Should I toss it and get a new one? If it matters the wheel and tire are both Mavic and intended to be tubeless.
You should be fine if it’s sealed. I would let most of the air out and refill with a pump tho. For some reason CO2 does weird shit to tubeless/sealant.I've had my road bike about 2 months now and today I had my first puncture. I plugged the tire as the sealant wasn't able to fully seal the hole. I topped it off with CO2 and went on my way. Can I continue to ride this tire? Should I toss it and get a new one? If it matters the wheel and tire are both Mavic and intended to be tubeless.
Road tubeless is amaze-balls.
I’m with you for sure. I haven’t had a single inner tube in my life for a decade.
4,700 miles. First flat. Tire #3 DOA
What rim and frame?
Are you trying to get bit by a tick?
For me, I’ve been meaning to buy a dynaplug kit. Thanks for the reminder
