Bravoporkchop
SPRINGTIME
It's begun. Early season clamoring of theoretics and strategemizing this year's approach to going faster.. NO wait, still have to conserve on the climbs, but spinning-out on flat was soooo last year for me..
And breeeathe
This season I decided to be a tad more methodical on choosing ratios and considered straying from my standard, tried and true, one-ring-to-rule-them-all ratio. So I made a chart.
THE CHART and THINGS I'VE NOTICED
The full chart spans ratio combos of Chainrings 30, 32, 34, 36 and Cogs 16-22.
My intention was to choose a ratio based on the ratio itself and not get hung up on tooth count.
Another factor in consideration is the unholy amount of stress applied at peak resistance. The diameter of the cog directly correlates to how much strain is transferred through the bike. Small cogs break chains and wear teeth, esp. if you run aluminum cogs. Larger cogs require larger chainrings to maintain a similar ratio. While this is less visually appealing it will help save your drive train. Having a chart handy is a good way to find similar ratios utilizing different cogs. See chart.
I have attached the chart as a PDF for you to print and slap on your tool box or lunch box with packing tape or just keep it handy on your phone. Comes in two flavors: Rattle Snake and Everlasting Gobstopper. Enjoy.
The PDF contains:
-full list of all ratios
And for the sake of brevity and popularity:
-list of only 32 ratios
-list of only 34 ratios
