Honeywell Thermostat code
Bike N Gear
Shop: Bike N Gear
Anyone know how to break into a Commercial Honeywell thermostat? My wife is stuck at work and their thermostat requires a code to adjust the temperature. It is currently set at 76 and no one is around with the code needed to make changes.
There are 2 types of passwords on these- the code to lock the temperature is set by the owner.
The dealer code is required for the other setup options- it's just the date code.
You can get the date code by: menu / equipment status (last line).
Not sure if you can override the user code this way.... sorry....
you typically have your home set at 76F on weekday when away at work? That's bleeding money son
When my kids go away to school, I'm dropping mine to 58F max
No. This was her thermostat at work. No ome had the code so they could drop the temp.
does it need a/c for that temp, or heat?
buildings are weird that way.
