Kaleidopete
Below is a pretty good explanation about GPS and distance ridden that I didn't consider if riding over the GW bridge or Bear Mountain bridge. Useless information, I know, but interesting.
GPS coordinates are on the face of the earth at that point, not on man made structures. so if you are riding up a bridge or on an overpass, the GPS coordinates (and therefore distance and elevation) will be based on the ground at that point, which may be a distance below you. I know others have had issues with elevation variations until they realize that they are riding over bridges so it appears level to them but in reality the ground is dropping out under them and the tracker thinks they are running on the ground. Since the ground covers more distance than the bridge it will over estimate distance and pace. This is simply the way GPS mapping works.
