Dictatorsaurus
Selling Sette Flite AM FS complete bike. I got the bike early this year and it's still in great condition. Most of the frame is covered with 3M clear protector.
A few minor paint scratches but overall looks great. I never rode this bike hard or did any jumps. However this bike is made to take a ton of beating.
Running 2x9 setup with BBG bashguard and Blackspire Stinger chainguide. Never dropped the chain even once!
The wheels have been converted to tubeless running split tube and homebrew sealant. Hold air great.
The Rockshox Domain 318 fork has a medium rate adjustable travel spring 160mm-115mm. The rear triangle has adjustable travel 4", 5" and 6".
Size Large 19".
Selling for: $700.
Extras included:
- Brand new 44T chainring
- Rockshox 160mm spring (medium rate)
- Rockshox 160mm-115mm u-turn spring (heavy rate)
Here are the full specs:
Frame: Aluminum 6061
Size: Large (19"/48cm)
Fork: Rock Shox Domain 318 u-turn Coil 115mm-160mm
Rear Shock: Rock Shox Monarch 4.2 (6"/152.4mm)
Shifters: SRAM X9 Twist shift
Front Derailleur: SRAM X7, Low Clamp, Blk, ø 34.9 Top Pull
Rear Derailleur: SRAM X7 Med Cage
Shifter Cable/Housing: Jagwire Slick
Brake Levers: Avid Juicy 3
Front Brake: Avid 185mm Rotor
Rear Brake: Avid 160mm Rotor
Hoses: Avid Hydraulic Hose
Crankset: Truvativ Stylo 3.3, 175mm, Black, 32/22T
Bottom Bracket: Truvativ Stylo 3.3, 68mm/English
Cassette: SRAM PG-970, 11-34
Chain: SRAM PC-971
Headset: FSA 1-1/8" Semi-Integrated/Internal - Black (Zero Stack)
Handlebar: Lightweight Alloy - Black
Grips: ESI Chunky grips (red)
Stem: Lightweight Alloy - Black
Saddle: Sette Amp saddle
Seatpost: Lightweight 6061 Alloy - Black, 31.6 x 350mm
Rims: Mavic EX729 32H Black
Front Hub: Sette 20mm Thru Axle, 6-bolt Disc Brake, 32H black, heavy-duty cartridge sealed bearings
Rear Hub: Shimano XT M756, 6-bolt Disc Brake, 32H Black, QR
Spokes: 14 Straight Gauge, Stainless Steel, Black
Pedals: Platform, Chromoly Spindle, Black
Front Tire: Kenda Nevegal 26" X 2.35, 60 TPI, DTC
Rear Tire: Syncros Point N Chute 26"x 2.35 60 TPI
Bike Geometry:
Pics:
Size Large 19".
Selling for: $700.
Extras included:
Chain: SRAM PC-971
Bike Geometry:
Pics:
