Ante Supe
For Sale: Specialized Crave SL 29 (Single Speed) Size Large - $950
Reasonable offers, NO TRADES.
Bike is absolutely MINT. It's been ridden less than 500 miles, and the tires have less than 100 miles. Alloy fame / Carbon fork, full specs. listed below.....
Weight: 20.6 pounds (with pedals pictured)
FRAME: Specialized M4 Premium Aluminum, XC 29 Geometry, fully-butted w/ smooth welds, tapered head tube, tapered seat tube, forged post-mount 160mm disc dropouts, replaceable alloy derailleur hanger
FORK: Specialized Chisel, carbon, monocoque, tapered carbon steerer, alloy dropouts, disc mount, OS28 hub compatible
CRANKSET: SRAM S-1255, singlespeed specific, GXP, 32T, 104mm BCD spider, 175mm length
CASSETTE: Singlespeed conversion kit, 18T Cr-Mo cog, alloy spacers, lock ring
BOTTOM BRACKET: SRAM GXP, 73mm
SADDLE: Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST: Alloy, 2-bolt, 12.5mm offset, 30.9mm
HANDLEBARS: Specialized Stout XC, flat bar, double-butted 6061 alloy, 9-degree backsweep, 4-degree upsweep, 31.8mm
STEM: Specialized Stout XC, 100mm length, 3D forged alloy, 4-bolt, 6-degree rise, anti-corrosion hardware
FRONT HUB: Specialized Stout XC Pro, Hi Lo disc, alloy, sealed cartridge bearings, QR, 24h
REAR HUB: Specialized Stout XC Pro, Hi Lo disc, alloy, sealed cartridge bearings, QR, 28h
SPOKES: Stainless, butted, 2.0/1.8/2.0mm, black
RIMS: Specialized Stout XC Pro 29, disc, alloy, double-wall, sleeve joint, 26mm inner width, tubeless ready, 24/28h
FRONT/REAR TIRES: Schwalbe, Rocket Ron, 120 TPI, Lite Skin, 29x2.25"
FRONT/REAR BRAKES: Shimano Deore, hydraulic disc, dual piston, resin pads
BRAKE LEVERS: Shimano BL-M506, hydraulic, reach adjust
HEADSET: 1-1/8" upper, 1-1/2" lower, threadless
SEAT BINDER: Alloy, 31.8mm
