Chris King 135 x 10mm Rear Thru Axle Conversion
Dingo
CK axle is easy peasy to remove. You will need the adjuster tool to make the bearing adjustment.
While you got it apart, might as well service the ring drive, using the ck lube. Real easy. Another axle option is the fun bolts, eliminates the quick release.
I bought the complete hub kit years ago. It has paid for itself. If your near freehold drop the wheel off.
link to "only" the bearing adjuster
https://www.artscyclery.com/descpage-CKHCT.html?utm_source=bing&utm_medium=cpc&utm_campaign=Shop: Tools&utm_term=1101000080989&utm_content=Tools Catch All
Some of the conversions need this lock ring.
https://www.worldwidecyclery.com/products/chris-king-15mm-thru-axle-adjusting-cone-for-hu7802-axle
