@Dingo , Here is the diagnosis:
A CUSTOMER STATES THE CAR KEEPS DYING WILL NOT KEEP RUNNING CHECK AND
ADVISE
CAUSE: ENGINE HAS SEVERE INTERNAL DAMAGE, DTC PO303 STORED.
CONCERN CUSTOMER STATES THE CAR KEEPS DYING WILL
NOT KEEP RUNNING CHECK AND ADVISE
7691 CPA 124.88 124.88
PARTS: 0.00 LABOR: 124.88 OTHER: 0.00 TOTAL LINE A: 124.88
108816 CHECKED FOR DTC, P0303 STORED, CYL 5 ALSO SHOWED MISFIRE IN
DATA DISPLAY. PERFORMED COMPRESSION TEST ON CYL 5 50 PSI, CHECKED CYL 1
130 PSI. THIS INDICATED POSS OUT OF TIME CONDITION AND FAILURE IN CYL.
3. SMOKE PUFFS OUT ON CRANKCASE INDICATING CYL. AND PISTON DAMAGE.
RECOMMEND REPLACE ENGINE.
B MPI VISUAL INSPECTION
MPI MPI VISUAL INSPECTION
7691 CPA 0.00 0.00
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE B: 0.00
C** DIAGNOSTIC CHARGE
10 DRIVEABILITY
7691 CPA 0.00 0.00
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE C: 0.00
