Brand New Wheelset and Other Misc New Parts
syadasti
Wet Rag
Shimano XTR M970 Rings
*wheelset gone*
Brand new never used Shimano XTR M970 chainrings. These came stock on M970 cranks and I decided to use a different ringset to suit my needs.
Inner 22T
Middle 32T
Outer 44T
Save big and buy the complete 22-32-44T set for $169 with free shipping - much cheaper than mail order sells them:
http://www.jensonusa.com/store/product/CG311A00-Shimano+Xtr+M970+Chainring.aspx
You can also pick them up if you like (central NJ area). Paypal only for shipped items.
Check out my perfect feedback record:
http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback&userid=topiparrot&ssPageName=STRK:ME:UFS
Will these only work on 970 cranks? I. Believe the bike I need them for has fsa cranks.
BCD is the same. The outer and middle ring have standard spacing but I know for sure the inner ring is not standard spacing. Keep in mind all the engineering, tech, and significant weight saving over conventional rings is in the middle and outer rings which is why they are so much more money than normal rings and the inner is relatively cheap. I had to buy an XTR inner 24T ring as my raceface ring did not fit the M970 crankset and I did not want to use spacers.
Left ring - XTR M970 granny. Right ring Raceface granny.
Would I be able to use the existing granny with the mid and outer?I don't use the granny anyway.
I don't see why not since the BCD is the same. Its best to start with fresh drivetrain components for optimal performance/wear - do you mean its a new FSA crankset and you'll just keep the stock granny ring?
I have been getting chainsuck on my outer ring and need to replace. The crankset is only about a year old so I figured this could be a good solution and an upgrade as well.
If you are going to be investing in expensive chainrings I would replace the year old (I assume) chain and cassette at the same time. An old chain with new chainrings will not have chainsuck but if you have to replace the chain and cassette later on and your newer XTR rings are broken in to your existing drivetrain the combo of worn rings with new chain will likely lead to chainsuck. You'll get best results if you start with a fresh drivetrain, but its up to you.
Here is a detailed site on chain-suck: http://fagan.co.za/Bikes/Csuck/
