Rockbottom
Finished a ride this past weekend and noticed there was excessive brake rub on the rotor with the front tire. So at home I go through the usual check list to see what the problem is: make sure the wheel is properly trued, check that the rotor is not bent, Re-align the brake caliper, loosen the caliper bolts, squeeze the brake while re-tightening bolts. Nothing really works. I notice now that there is virtually no space between the brake pads and rotor. So I take the pads out and try to reset the pistons, but after a few squeezes on the brake with everything back together, the same issue persists. Anything else you recommend at this point?
Brakes are Magura MT7 (dual pistons)
