After my initial snow riding technique, thread. I been doing a little research on tires that work in snow.
Snow tires, like sand tires, need to have widely spaced knobs, that can have isolated pressure points as opposed to a regular mountain tire for hardpack. Well you guys are educated folks, so let me give you my idea of snow tire setups.
My Set up.
I currently run Specialized Eskar Armadillo Tires front and rear following the rotational pattern. I believe if I were to switch the rotation on the rear, I would get more into the snow, but still not enough with 20psi cause the tire is a little stiff (due to anti-puncture layer) and does not create optimum pressure points for bite.
I used to run Specialized Captain tire front and back, due to their fast rolling characteristic and numerous knobs, it sucked in snow.
What set up I would like to test.
Front:
Panaracer CINDER (26X1.95)
REAR:
Panaracer CINDER (26X2.25)
Front:
Panaracer Cinder (26X1.95) Rear:
Panaracer Rampage (26X2.35) Opposed direction
Front:
Panaracer Cinder (26X1.95) REAR:
WTB VelociRaptor (26X2.1)-supplied Rear Tire
Forgot to add these
Wide rims and studded tires in this tutorial would help >>>
http://www.icebike.org/Equipment/rims.htm
Studded tires >>>
http://www.biketiresdirect.com/suzz/studded_tires/products.htm
