goodvibe
I have ridden a Beargrease since 2014 and I loved it. Back in March, I decided that it was time to upgrade and I decided to build a new Mukluk from scratch. I didn’t like the matte finish, so I paid a professional bike painter to put a light clear coat on the frame. It looks awesome!
So after 200 miles, the new Mukluk didn’t ride like my Beargrease, so I just bought a new Beargrease Carbon NX. I put my Mukluk parts on it and I am selling the parts off the Beargrease that are all brand new and never been used. I can sell the parts separate, or I can build the bike for you if you would like.
Frame-Mukluk ($1250)
The Mukluk is Salsa’s most versatile fat bike, designed and engineered to excel in a wide variety of conditions. Available with 12x197 mm rear spacing to accommodate up to 5" tires, and a 100 mm threaded bottom bracket allow for a wide range of crank (q-factor) choices. Alternator dropouts support multiple configurations; singlespeed or geared, rigid or suspended out front, or make use of the stealthy and integrated Alternator Rack/Rack-Lock systems for added carrying capacity via traditional racks and panniers. The Mukluk is made to do it all.
Drivetrain
- Carbon frame with 12x197 mm rear spacing and thru-axle
- Salsa Makwa 15x150 mm thru-axle carbon fork
- Mfg Size: Small
- TT (Effective): 59.4
- Frame Type: Rigid
- Fork Type: Rigid
- Wheel Size: 27.5" Fat , 26" Fat , 29+
- Frame Material: Carbon
- Fork Material: Carbon
- Color: Yellow/Olive
- Defined Color: Yellow
- Front Axle: 15mm Thru x 150mm
- Rear Axle: 12mm Thru x 197mm
- Brake Type: Disc
- Headset- Cane Creek 40
- Front Thru Axle / Deadbolt Ultra LightThru Axle
- Rear Thru Axle / Deadbolt Thru Axle
Drivetrain
- Crankset- SRAM NX Eagle DUB, 30T
- Bottom Bracket- SRAM DUB
- Rear Derailleur- SRAM NX Eagle
- Cassette / Cog- SRAM PG 1230 Eagle 11-50t
- Chain-SRAM Eagle
- Grips / Bar Tape- Salsa File Tread Lock-On
- Handlebar -Salsa Salt Flat (XS-SM)
- Stem- Salsa Guide Trail
- Rear Shifter-SRAM NX Eagle
- Brake Levers-SRAM Guide T
- Brakes-SRAM Guide T
- Rotor-Centerline 160mm
- Saddle-WTB Volt Comp
- Seatclamp-Salsa Lip-Lock
- Seatpost-Bontrager Race
- Front Wheel-SUN Ringle Mulefüt SL 80 27.5" x 80mm w/ SUN Ringle SRC 150mm Hub
- Rear Wheel-SUN Ringle Mulefüt SL 80 27.5" x 80mm w/ SUN Ringle SRC 197mm Hub
- Tires-Maxxis Minion FBF Front and FBR Rear, 27.5" x 3.8", 120 tpi
