Its tapered w/ 9mm dropouts. You have to see if your headtube is compatible with a new headset.
M mpope68 Active Member Jan 20, 2019 #61 Its tapered w/ 9mm dropouts. You have to see if your headtube is compatible with a new headset.
TimBay Well-Known Member Jan 20, 2019 #62 mpope68 said: Its tapered w/ 9mm dropouts. You have to see if your headtube is compatible with a new headset. Click to expand... Hmm. I should be anle to get an ec 44/40 to make it work, but that'll add a little length. It's a 29er right?
