Need trailside help
If you pull’d it up you’ve fubar’d it. You’ll need to bleed it. This is what reverbs are known for.....
Don’t use a reverb in the winter. Or at all.
Haha yeah this. I had the same thing happen on a sourlands ride. Since I wasn't carrying a clamp to keep it up, had to abort and ride home in clown bike mode. That was the end of the dropper post on my horsethief.
Sounds like a personal problem :eek:
I had reverb issues in the winter as well. I had to rebuild, but see if things resolve in warmer temps.
Hold the button down, while pumping the seat up-n-down.
eventually it will stay up, or have a little play at the top.
Just realized your out on a ride. See if what @fidodie says works. I had to ride mine in the down position when it happened to me.
So I was gonna finally install my Fox is this a problem with all droppers in the winter. Should I just wait till spring.
no, never had this problem with my droppers in the winter. but mine arent hydraulic to the lever either . . .
turn the speed adjustment all the way up too.
and check the air pressure in the cold. might be low.
