Monkey Soup
Angry Wanker
If you have a Pike, get the Vorsprung Luftkappe. It’s a larger negative air-chamber that will replace your tokens, and is the best $85 you’ll spend on that fork. I’ve been running one all year, no issues with trapping air. Ff
If you have an older Pike, get the Vorsprung Luftkappe. It’s a larger negative air-chamber that will replace your tokens, and is the best $85 you’ll spend on that fork. I’ve been running one all year, no issues with trapping air. Small bump sensitivity is amazing, and as an added bonus, makes your fork more progressive so nice support around the sag point with nice ramp-up for soft bottom-out.
Good to know, I have the 2015 Pike and if some tokens don't do the trick, this may be next
