Need a pf30 Shimano compatible BB
extremedave
It's a Raleigh Tripper with a PF30 bb, but according to the spec sheet it's supplied with an FSA eccentric. Has Tiagara cranks so obviously it's setup up for Shimano diameter. Whatever it is, I need a new one.
The standard FSA unit shows as about $85 on Amazon, since this bike was one of my worst used bike purchases overall if there's a more cost effective alternative that would be spectacular.
i think i have a wheels manufacturing insert to convert it to normal bearings and gpx
special deal for you.
extremedave
Then I'd need a sram crank doe?
The bearings are toast so none of the adapters that use the stock bearings will work. Maybe I just need to spend the dough.
It doesn't need to be eccentric though. Maybe there's a less spendy normal version.
nothing in the parts pile? surprising.
extremedave
Fire, always fire...
