rlb
wonder if an air hammer would do it ? should be able to catch the lip from the back with longer bit.
work each side until loose.
I like this idea, I do have one. Will try...
Bent shaft from rock strike?
Masonry work is not easy, for me getting the mortar the right consistency so it sticks to the sides of the blocks. I had an engineering fail this past week. Thought my masonry wall would hold up 5 yards of pea gravel. Additionally, the gravel bog empties into the pond so expected the water pressure to hold back the wall. Did the deconstruction on Saturday and rebuilt the rear course yesterday. Filled in the blocks this time with cement but no rebar. The section which fell needs more. Was thinking to use rebars but my brother suggested this. Anyone know where I can get it?Got all the loose crap out. Need to mix some cement and patch. I’ve got that extra wood for forms which will work nicely. As I was chipping away, the guy running for city council dropped into my yard and was like.... hey you’re doing what I do and preceeded to give me advice. Some of which was helpful but not what I was planning to do. He’s got my vote already!
Still need to get that chunk out of the bottom stepView attachment 68413View attachment 68414
Still need to get that chunk out of the bottom step QUOTE]
Prolly easier and quicker to knock down and build wood stairs , you will be repairing in 3 years again .
Start a free doggy day care. Give them water, then put them in this room for a few hours.Finished painting trim in the front, power washed siding and rear deck/stairs (btw the old power washer died, a craftsman - if anyone wants to try to play with it, it's free. If not, it goes to the dump. It ran not well for a few hours, then when tried to start it a few days later, wouldn't run at all. Just starts and dies. Fiddled with it for awhile, then gave up and bought a new one).
Next project is this - hardwood floors have several stains from dog urine - I tried several years ago to bleach it multiple times, this was the best I could get it):
What are the options? Replace the boards? Or sand and re-stain the entire floor to a darker color? Gotta sell this dump soon!
gas unit? fiddled with it how? (i like tinkering with gas motors for good or for bad)
Oxalic acid helps..... A LOT. but it still won't be perfect. Ideally you would strip any poly over top just to get it through as much as you can.Finished painting trim in the front, power washed siding and rear deck/stairs (btw the old power washer died, a craftsman - if anyone wants to try to play with it, it's free. If not, it goes to the dump. It ran not well for a few hours, then when tried to start it a few days later, wouldn't run at all. Just starts and dies. Fiddled with it for awhile, then gave up and bought a new one).
interesting . . .if you jsut tossing it and you come to a friday ride ill take it off your hands, worst case it ends up on my garbage pickup instead of yours . . .
my thinking is its hard because of the height difference. Floor guys do work miracles. Machine sanding will remove more color but not perfect. My areas were nearly black. between the oxalic and machine sanding (done myself) and staining golden oak it was reasonable. I'm sure a pro will have options but of course at a price.I used that as well. Sanded the surface and multiple treatments with oxalic. It was a lot darker before. So how hard is it to remove sections and replace?
it needs a new carb - probably $15 on amazon or ebay
