The DIY thread - DIYourself
I went with Chinese Amazon under cabinet set-up with a quality power supply. 4" recessed lot lights with 3k LEDs, matches the cab light. Doesn't match the hood light such is like 5k and looks weird
What PS did you use?
This is from steaming off the old glue? What are you putting down? If someone is laying the floor for you I'd check with them.
putting down hardwood - i know i know, not in the kitchen. but i even had a wood flooring guy come in and say "i never tell people to put wood in their kitchen, but if you put anything but wood in your kitchen, it just wouldn't be right".
i have let it dry plenty - checked with the floor manufacturer - i'm good with moisture level.
when i went to move my kitchen light i found a new weird thing. i will post it up when i get home.
  • Like
Reactions: rlb
We took up tiles to put down hardwood in the kitchen. Had to go with thin boards because of transitions and they have held up well. Just keep a mat under the cat/dog's water bowl.
wood in kitchen is fine - just accept that it is a high traffic area, and will need refinishing.
or just move.
So here's my new finding. I was punching holes in the sheet rock for boxes for my new fancy-dansy lights. And I found not a joist, but a plank of wood...
i'm looking at that, and thinking it was used as a backer for a repair in the area????
Ok - makes sense. I have to pop off a large area of the ceiling anyway. It's right under my upstairs bathroom, so I assume the leak I have experienced is not the first leak this bathroom had.
According to this thread my kitchen has been back in commission for about 4.5 months, so I figured today would be good time to install some handles and adjust the door on the sink base I replaced. Just stole the ones from the old cabinet, so at least they'll match the shitty style of all the existing handles.
What's a pump I can use for draining a pool of water such as this:
I can get electricity there. I have one of these:
Once I drain it, what's a tool I can use to take out all the sludge from a 2x2 feet square hole about 4ft deep?
if you can borrow a macerating pump, it may clear the sludge...
otherwise any generic small sump pump - i have one, i use to drain the water from the top of the pool cover that has a connection for a garden hose. not sure how to get it to you.
scoop out sludge with Ladle?
There are gas powered pumps if your battery pack isn't big enough.
google cleaning sludge from bottom of sump pit......
i have one you can use
That home depot pump should work. When you are done with it, throw it in a 5 gallon bucket of water to clean out any sludge that gets stuck in the pump.
power snake is the way to go for clearing the drain.
post hole digger - not way to go - get a long handle shovel and bend the end to do the scoop job you need
you'll need a pump, a hose, and a way to connect them.
don't use a garden hose, too small for any real work - they sell a flex hose just for this.
you are going to need real power tho - these things are 1/2 hp . will draw 10 amps.
http://www.homedepot.com/p/Wayne-1-...stic-Submersible-Utility-Pump-VIP50/100034817
http://www.homedepot.com/p/1-1-2-in-Discharge-Hose-Kit-66000-WYN1/100119536
should do it.
