Idk if conti is blowing out the 4000s Ii, but they are dirt cheap nowWell, I cheaped out. Kept my 4yo gatorskins. They still have flashing. I'll go to new gp4kii in may. Or get a new bike.
I hope my Contis are 4000's. I will wave you down. Will update later.Just an FYI. If you are stuck with a flat on 4000s, Evo Corsas, or Turbo Cottons, I'm leaving you for dead.
impressive logic.I'll go to new gp4kii in may. Or get a new bike.
Pat- the schwalbe marathons are worthy of consideration.
Think a rear fender is needed or just use that ridiculous cardboard thingy they give you
impressive logic.
do these come on new bikes?
will make a game day decision - have an s-blade. you should have one, since i'll be behind you.
the folks here have freely shared the way of the bike, i only seek to be a worthy student.
I managed to tear a nice hole in the sidewall of a GP4000sii last year at Fools Classic, didn't flat though! Tread protection was fine but the sidewalls were thin.Just an FYI. If you are stuck with a flat on 4000s, Evo Corsas, or Turbo Cottons, I'm leaving you for dead.
The II's measured 28? The old 4000s were maybe 2 mm larger than the size but I have found they are more true to size in the II's. +5 mm seems like a stretch. In any case, the dirt roads in the Fools Classic use a much larger stone than the NJ side.I managed to tear a nice hole in the sidewall of a GP4000sii last year at Fools Classic, didn't flat though! Tread protection was fine but the sidewalls were thin.
edit: for those curious I was on the 23mm flavor with Pacenti SL23 v2 rims. Tires measured 27.5-28mm and were fine.
Interesting, I can fit 27 Vittoria Pave's on my 2015 EVO on Dura Ace C24's@stb222, I measured both tires with a caliper gauge and they were both above 27.5mm. I forget the exact measurement. The SL23 v2's measure 20.3mm internal so certain tires end up VERY large on them. I can't run 23mm 4000sii's on my 2015 SuperSix EVO without tire rub on the NDS chain stay.
That's what she said.Interesting, I can fit 27 Vittoria Pave's on my 2015 EVO on Dura Ace C24's
